More Roland Headaches
Discussion in 'Roland' started by SignGuyNate, Aug 29, 2013.
  1. SignGuyNate
    SignGuyNate New Member
    16
    I'm having a heck of a time with my Roland lately. I'm at the point where I have to calibrate the cut and the scan/feed before every job, but in as little as 36 inches of material later my print is completely distorted and my cut is up to a half inch out of alignment. It's almost like my material is drifting, or in crooked, but I've got it locked in pretty tight. Anyone dealt with this issue before?
  2. SignGuyNate
    16
    Not that I can tell, yes, yes, yes and yes as far as I know. I will wipe it down later on today and see if it helps. It's just weird. I didn't have this issue until last week, when the power went out suddenly three times in the middle of running a job.
  3. jfiscus
    jfiscus Map Wraster
    3,201
    239
    63
    Apr 2, 2009
    Cincinnati, OH
    Do you motice the drifting in your prints theirselves? I would try printing a 4'x8' "checkerboard" of exactly 1' squares, then check your results to see how it is skewing.
    I am suspecting your linear encoder strip is dirty, although when it goes wonky, it is usually VERY noticeably stair-stepping...
  4. Gino
    Gino Premium Subscriber
    33,488
    2,384
    113
    Jun 7, 2006
    PA
    The power going out could be an indication of some kind of communication failure. Communications or intermittent signals could cause any number of problems with your equipment.
  5. CS-SignSupply
    CS-SignSupply Very Active Member
    We recently had a situation where the printer printed the file properly but when returning to cut, the cut data was being distorted.
    Turned out to be mainboard. Processor sending corrupted data to servo board.
  6. xxtoni
    xxtoni Member
    164
    1
    We had a similar issue months ago with our VS-640.
    Prints would have banding on them and cuts wouldn't be accurate.
    Dealt with the dealer for a while, they wasted a lot of our time. One of their guys came out and concluded that the servo motor controlling the feeds must be shut. Then they said that they have to consult with the head office in Italy and after they confirm they can order the motor from Japan.
    Long story short - We took the machine apart and found some ink had made it's way onto the encoder strip. Took a bit of alcohol and cleaned it up, worked like new.
  7. SignGuyNate
    16
    Stair-stepping. That's what I'm getting. Couldn't find the words for it.
    No, the power to the building went out three times. Someone working on the bridge a half mile down the road damage a cable and knocked this whole side of town out. Was up and down while the power company was trying to fix it, but every time it went out my printer was running. That's not to say there isn't an issue with comm now because of that, though.
    I hate calling the dealer. I especially dread it in this case because I don't know how to explain what's going on.
    I cleaned the encoder strip and did the limit initialization procedure, and now I'm loading a banner job. So in about 20 minutes we'll see how it went...
  8. SignGuyNate
    16
    Well, the media is walking, but not a lot. A 1/16th of an inch to the left over 8 feet.
    I changed the print to uni-directional and the issue seems to be less noticable, but it's still there. I suspect the encoder strip and/or the encoder sensor needs to be replaced.
  9. mbarden
    mbarden Active Member
    596
    2
    18
    Oct 1, 2006
    Iowa
    The VS Series of Printers has a new encoder that previous Rolands do not have. The oncoder controls the grit rollers actions. Open the right and side of the printer, 2 top pieces, the piece around your power cord and the right hand side piece should be removed. Take a dry paper towel or lint free cloth and clean the "circular" encoder disc that is attached to the right had side of the grit roller. this should solve your problem.
  10. SignGuyNate
    16
    Yeah, I have a VP series though.
  11. P Wagner
    P Wagner Very Active Member
    1,923
    83
    48
    Aug 16, 2006
    San Diego
    I am confused. Is the media moving laterally (walking) on the printer platens, or is the printed output stair-stepping on the media (or both)?
  12. sdodson1
    sdodson1 Member
    49
    Just this week I had an outer roller cover come loose and run cockeyed on the inner brass roller that holds the bearings. Called and got 2 to replace both oters and no more problems! Might be worth a check
