Motor Error on Roland SC500
Discussion in 'Roland' started by prettybird, Dec 12, 2009.
  1. prettybird
    prettybird New Member
    19
    Hi, we have a Roland SC500 and it has been having a motor error. We have the service manual and are going to do the steps it says to do to determine what is the problem, but when we try to enter the service mode, it says service mode protected. We are pushing the buttons it says to push in the manual but it won't let us into service mode. Does anyone know what to do? Thanks!
  2. sfr table hockey
    sfr table hockey Very Active Member
    1,212
    Jan 24, 2009
    Alberta
    With the main power on but the front pannel is off.
    Press up,left,right, down (kind of like a S shape)
    Then left,down,right (like a V shape)
    Then hold the left,down,right (V shape again) all down together and press the front pannel power on.
    You might get a service menu protected a few times if you don't hold the key pad arrows down just right.
  3. prettybird
    19
    Thank you! We got it to go in now.
  4. mudmedia
    mudmedia Active Member
    507
    We kept having a motor error and a dispatching of carriage error as well...I read the service manual thanks to the 101 Community who gave me the link! And we did the initializing test "I think thats what its called?" I think it was left up and right hold and press power...It did its check and reset the settings to the proper ones and not having any problems since! I dont know if this is your issue but it helped ours!
    Good Luck
  5. Pacific Coast Sign
    Pacific Coast Sign Active Member
    548
    1
    18
    Jun 19, 2008
    Portland, OR
    If you can't get it, give me a call, there can be several issues that give the motor error message...do some homework before you spend $$$ for a new motor that may not fix the issue and the motor cannot be returned.
