Need Help Mounting 6m x 1m aluminium sign
Pauly
Printrade.com.au
I need a way to mount a 2 piece 6m x 1m aluminium sign to a concrete factory. Each piece is 3m x 1m
I'm not quite sure how to do it in a nice way. Yes we print these all time, but never mount them as the client usually does this.
I'm not sure what fixings to use, i.e dynabolts? or is there something else? If it was mounted to sheet metal, i'd use larger pop-rivits.
Bly
Those nylon anchors. Drill the hole, push the plastic part in then hammer in the pin.
Ramset brand are best with the phillips screw head. They are easy to remove.
Cheaper ones not so much.
JohnBFryJr
Those work really well. I've been known to use the metal ones as well
Sent from my SAMSUNG-SM-N910A using Tapatalk
Pauly
Printrade.com.au
I thought i could use those. Thanks! They seem so small and feel like they can rip out. i guess not.
