Mounting Digital print to 10ft panels
Discussion in 'Digital Printing' started by Rising, Aug 13, 2010.
  1. Rising
    Rising Member
    78
    Evening all (afternoon)
    We run a jv33 and have done many jobs where we need to moun t the laminated prints to panels large and small. Large panels are, even with the laminator, a bit of a pain in the a$$. We did a load just recently to 10ft panels for an expo, but seemed to take an age as we wanted to make sure they were straight to the edge as each panel made up a bigger image.
    Anyone have any tips on how to mount prints to panels and making sure they mount dead straight and square so when butting up each panel they join is perfecto?
    Many thanks
    Steve
  2. 300mphGraphics
    300mphGraphics Active Member
    518
    5
    18
    Aug 15, 2006
    arizona
    Don't butt the edges, over-lap them.
  3. Shovelhead
    Shovelhead Major Contributor
    10,882
    16
    A helper with long arms.
  4. miguelon.lizarraga
    miguelon.lizarraga Active Member
    718
    What do you mean by this?
  5. marcsitkin
    marcsitkin Member
    168
    1
    Print them with a bit of overlap, and take the trimmed edge from the first board and use it to mark the edge of the next image.
    It's much easier to do this if you have a RIP that will handle the tiling for you, and if you have a hot roller laminator, a mount adhesive like Drytac MHA, which is easy to reposition and only adhears once heated.
  6. Rising
    Rising Member
    78
    we do put a 10mm overlap on em, but we make panels in the workshop then install off site. The prob is keeping the length true and straight and square. We can do it, just takes a while. Pressure on the laminator is consistent so any stretch will be the same, just seems to wanna move about a bit on long panels.
    Steve.
  7. omgsideburns
    omgsideburns Very Active Member
    2,180
    Apr 15, 2008
    we install graphics on the panels wet, side by side on the table to make sure they line up.
