Mounting Gemini letters on granite
michsanford
Any suggestions on drilling into a granite wall to mount Gemini letters? We need a 3/16 hole, but about 200 of them.
Billct2
What kind of granite wall, interior , exterior, smooth, rough...what material letters, how big?
Moze
I third that. SDS rotary hammer. NOT a hammer drill. If you don't have an SDS, now's the time to invest in one.
BobCap
Drill 200 holes...it'll take you a month. I hope you are charging enough...
I would use 3M VHB tape. If it's good enough to hold trim on your car...
Or some other kind of adhesive.
Bob Cap
AAI
Gilbert N
Jester1167
SDS+ hammer drill
Sometimes it is more accurate to start with a smaller bit on textured walls. The larger bits tend to walk more when starting the holes. Also bring a larger" bit for the few misaligned holes that won't allow the letter to sit flush.
If you have a leaf blower, bring it. They work good for blowing off the wall and the holes out before installing the letters.
letterman7
Ok, I'll ask: what's the difference between the DeWalt SDS and the "regular" DeWalt "hammer drill"? They look nearly identical to me except for the switch on the side of the SDS (of course, I have an ancient hammer drill here).
Moze
Bob Cap
AAI
Gilbert N
It'll take about 2 hours.
How exactly would you go about mounting a (edit: an 18") formed plastic letter with VHB and silicone?
Moze
An SDS rotary hammer delivers a lot more impact energy than a hammer drill.
Jester1167
I wouldn't think he would need to worry about chips, the wall is textured and the strokes on the 18" letters will cover up any small chips.
Billct2
That's why I asked for deatils, if it was aion interior wall, flat & polished I'd do VHB & silicone. Exterior flat, maybe a short stud with pad/silicone. Exterior roughgranite you gotta drill baby drill. And I agree it's a good idea start with a pilot hole.
Moze
Granite doesn't tend to crack. It WILL break out on the back when the bit punches through if the granite isn't adhered to a backer, but since this is an outside wall, that shouldn't be an issue.
42 holes, no cracks, just break-out. Skip to 4:50 to see what it does to the back.
[video=youtube;HhBdm3WeUC4]https://www.youtube.com/watch?v=HhBdm3WeUC4[/video]
