Mounting raceway on existing brackets
imajenn
Can anyone tell me how I would mount raceways on the existing wall brackets? And would this only allow me to do one raceway? Our client will have 2 lines of text so they will need 2 sets of raceways - similar to the example mockup attached.
Sincerely,
Designer new in the electrical sign world
To be safe and not sorry, if you can't get this far..... do you have the ability, insurance and proper licensing to do this once you halfway have it figured out ?? If you, personally, aren't putting it up, you should have someone who knows what they're doing making up the drawings. You hafta submit these to the municipal codes department and probably have engineer stamped drawings, too. It's your buns on the line if something g goes wrong.
visual800
you do not need 2 sets of raceways, your art is showing the capsule attached to main copy by hanging under it, you should be just fine. Open top of raceway and screw into channel on building using large taps screws. Thats actually a good idea for a storefront to keep from getting a million holes in fascia.
