DrunknMonk
Has anyone moved from Onyx to Caldera RIP, if so did you have any problems, HP 365 printer, Summa S2 roll to roll, & flatbed cutter, is what im using.
Both Onyx and Caldera would much rather sell you their nesting software than the RIP to tackle those challenges.the main reason is, tru nesting & adding bleed to cut files on irregular shaped artworks.
I don't believe Onyx has that option, TruFit will nest but I don't think it will add bleed for doing contour cutting, that's why Im thinking of moving to Caldera.Both Onyx and Caldera would much rather sell you their nesting software than the RIP to tackle those challenges.
I think it does have it.I don't believe Onyx has that option, TruFit will nest but I don't think it will add bleed for doing contour cutting, that's why Im thinking of moving to Caldera.
Caldera does a kind of true shape nesting (is named "contour nesting") as a standard feature, without additional costs. And a Caldera Softrip for a small or midrange printer like a Latex 365 is not neccessarily more expensive than an onyx postershop. And Caldera, in opposite to onyx, allows manual nesting too in the main app. I like Onyx, but I like Caldera too.Both Onyx and Caldera would much rather sell you their nesting software than the RIP to tackle those challenges.
Yeah I know, it does the 90° turns. You forgot he also has flatbed cutter.Caldera does a kind of true shape nesting (is named "contour nesting") as a standard feature, without additional costs. And a Caldera Softrip for a small or midrange printer like a Latex 365 is not neccessarily more expensive than an onyx postershop. And Caldera, in opposite to onyx, allows manual nesting too in the main app. I like Onyx, but I like Caldera too.
have you tried trufit?I don't believe Onyx has that option, TruFit will nest but I don't think it will add bleed for doing contour cutting, that's why Im thinking of moving to Caldera.
60 day demo... or longer if you ask for it. Mine was 120 days before I finally purchased it.I think it does have it.
Anyway get the 30day Demo for whatever you are most interested in. Caldera has pretty different workflow and I've seen people going both ways from caldera to Onyx and vice versa.
You can also use Prime center with Onyx. Doesn't have to be caldera.
do you find any problems with it ?60 day demo... or longer if you ask for it. Mine was 120 days before I finally purchased it.
I haven't used Onyx before so I can't give you any comparison there -- just pointing out that you can get extended demo time with Caldera if you ask them (which I think is necessary for RIP software because it's hard to fully test such an application when you've already got a busy schedule -- especially if you're going to set up custom profiles, workflows and other functionality where the product really shines).do you find any problems with it ?
(Onyx Thrive) you can add cut boxes and bleed but not to irregular shapes, the trufit trial ive used works great for nesting it won't do bleed, its not worth £1800 (uk money) its not just about saving materials, which are cheap, labour is very expensive so Its more about that than the materials, we had a job in last week that needed the designer to spend all day, adding bleed and cutting paths (55 jobs) with wages / taxes it cost me approx £100 for the day, so you do this once a month that's £1200 a year, so you reduce your time and materials with Caldera and maybe save £600 a year, I paid £3200 for Onyx in 2015, done 3 updates @ £1200 each, bought the grand format for cutting £1200 that £8k, I can buy Caldera all in for £2800, so Im saving say £600 a year in time (just on that one job) 4.5 years its paid for its self, that's my way of thinking but not sure its the correct way, been in the job 26 years and open to new waysIm not sure the juice will be worth the squeeze; especially if you are comfortable in Onyx. You absolutely can use onyx to create automatic cut boxes on pdf's and add bleed. I believe if you have a custom shape file with a cut file you can also add bleed to that. I'll try to confirm. But TruFit from Onyx would be a solution for tru shape nesting. Again, you need to be running a boatload of material to justify a rip move IMO for this issue alone. For the learning curve, time and cost I would need a whole lot more reasons then to save a few pennies on on vinyl.
Saving $600 a year doesn't sound worth it to me.(Onyx Thrive) you can add cut boxes and bleed but not to irregular shapes, the trufit trial ive used works great for nesting it won't do bleed, its not worth £1800 (uk money) its not just about saving materials, which are cheap, labour is very expensive so Its more about that than the materials, we had a job in last week that needed the designer to spend all day, adding bleed and cutting paths (55 jobs) with wages / taxes it cost me approx £100 for the day, so you do this once a month that's £1200 a year, so you reduce your time and materials with Caldera and maybe save £600 a year, I paid £3200 for Onyx in 2015, done 3 updates @ £1200 each, bought the grand format for cutting £1200 that £8k, I can buy Caldera all in for £2800, so Im saving say £600 a year in time (just on that one job) 4.5 years its paid for its self, that's my way of thinking but not sure its the correct way, been in the job 26 years and open to new ways![]()
the £600 a year was a rough guess on that one job, I would be more once we got use to the RIP, we can run it on the windows 7 PC, the RIP guy said he would install Linux on it so no other costs, Im still not sure I want to do this, thats why I asked on here for other peoples thoughts.Saving $600 a year doesn't sound worth it to me.
You also are not factoring in learning to use the software. That will slow your production down till your prepress has a full understanding of it.
Also it run on Linux or macOS, not windows. Have you factored in either a New RIP PC (Mac)? or running you current RIP PC on Linux?
I don''t pay my designer, I don't have one thats one of my many hatsYou pay your designer $100 for a days worth of labor? No wonder they take a whole day to add bleed / cut path to 55 jobs...
Asuming its vectors (Even if not) You can create an Action in illustrator to do it automatically at the press of a button. A few sanity checks/zooms to make sure it didnt mess up, and it shouldnt take more than 1-2 mins per file, unless its super complex.
