Mutoh 1204 print head
Discussion in 'General Chit-Chat' started by BAD NOVA, Sep 18, 2020.
  1. BAD NOVA
    BAD NOVA Member
    56
    1
    8
    Mar 11, 2017
    Alliance Ohio
    I did a head/damper change lost ink to cartridges, have air bubbles what's the best way to fix this?
    Thank you Brian
  2. Solventinkjet
    Solventinkjet DIY Printer Fixing Guide
    4,189
    783
    113
    Aug 2, 2011
    Denver, CO
    Run a couple long cleanings and it should suck the ink back down into the head. Once it hits the dampers it should stay.
  3. BAD NOVA
    BAD NOVA Member
    56
    1
    8
    Mar 11, 2017
    Alliance Ohio
    I did 4 cleans and nothing.
  4. Solventinkjet
    4,189
    783
    113
    Aug 2, 2011
    Denver, CO
    Then your cap top or full maintenance station is not working properly. Usually people change the cap top first as it's cheap and easy. Also, double check that the head is seated nice and flat. It is very common when replacing the head that the left side is higher than the right and you need to wiggle it a little to get it to drop down all the way. Take a look at the gap between the head and th eplaten and you should be able to see if that's the case.
  5. BAD NOVA
    BAD NOVA Member
    56
    1
    8
    Mar 11, 2017
    Alliance Ohio
    The head is seated. I also tried pulling ink thru the maintenance station with two syringes one is sucking air the other wont pull anything.
