Mutoh 1324 lose magenta after total service
jim_papa
Hello everyone
Because of the corona virus I had turned off my printer full of cleaning liquid.
Today I tried to get it back to print but none of the tubes got any ink. In the afternoon I did total service, change all the ink tubes, (disable the valves), change maintenance and dampers. All of them with genuine parts.
After initial charge, (which had perfect ink flow) magenta don't fire at all!!!
I made several cleanings and little charges but nothing. I can not see any line of magenta. The other colors are perfect.
I have to say that at cap i see magenta. And every time I make a cleaning, at the tubes under maintenance, I can see the magenta flows.
What can I do to fix it? You thing that head is off?
I'm looking forward for your answer...
Umca
Try to excahnge Magenta ink lines on dampers inlet with some other ink channel. And make a Little Charge. You will see is it printhead (damper) problem or ink lines.
