Woodsey3
I started having issue 2 days ago with the carriage almost finishes print and stops on left side then throws the code. I have cleaned the T-Fence/encoder strip. I tried to run another print - same thing. Double checked everything over tried running another print which it only printed the registration line which is faded (brand new head & belt). Went ahead one more time after moving the head manually to check that nothing is catching and now it will not leaving capping station. Where to start - what all should I replace (learn how to) or is there a service technician in Michigan.
