Cy Fan
I was having trouble with my Falcon I outdoor 48" originally there was a head crash so I had to replace the print heads. However after replacing it will not print Magenta during the nozzle check.
I checked all the feed lines and none had leaks, the dampers have ink in them and are air tight, and I can see that the pump is moving ink thought the lines.
Any other thoughts would be a big help!
