Hello all,
I have a Outdoor 62 " printer that has become a pet project of mine now that I have dumped sooooo much money into it. After sending out the motherboard to be repaired, replacing the dampners, capping station,ink pump, motor, and head fuses, the printer will still not print, it tries but no ink flows, the lines are empty, I can pull ink through the lines but it will not do it on its own. I tried the 'fill' utility on the menu but that just makes the motor make a whining noise that drives you crazy but pulls no ink. Any ideas on this? anyone with experience with this printer, on the fill cycle is the ink pump and motor supposed to be running, mine cycles a little at the end but just whines for the 4 minutes. THANKS !!!!
