Mutoh Falcon Outdoor Color Fading Out???
HVSS
Hey,
I am new here and I have a pretty weird problem. All of a sudden, when printing a photo, the colors are getting completely washed out. I am running a bit of an old machine, I have Mutoh Falcon Outdoor. I am attaching an image so you can see what I mean. Any help or guidance would be greatly appreciated.
HVSS
Thank you. Is this something that I might be able to fix myself or should i get a tech in here? I am unsure of how to unclog the line or empty the damper. I really appreciate the quick response.
Compilla
1) Take the top cover off and look for kinks or holes on the ink lines.
2) Take the head plastic cover off and inspect the dampers, they might be clogged , or an air leak.
3) YES YOU CAN FIX IT !! IT IS NOT THAT HARD !
S
Sign-Man Signs
Guest
Might want to try a ink fill on all colors. Sometimes ours starves out. Haven't figured out why yet, but fixes the problem most of the time.
Graphicdetailsinc
If an ink fill is fixing your problem, then you must have a small vaccum leak somewhere. Check you o rings where the metal lines meet the plastic tubes by removing the large lid cover thats on top of the machine. Also this will allow you to visually inspect the lines for air bubbles ect.
Cy Fan
If it is a damper or ink line problem, sometimes a couple power clean cycles does the trick
