CheapVehicleWrap
Everyone changed alright...to Roland. Try searching...if you have the time. It's been a "we never heard of such a problem" for 9 months?? now.
Amongst many other problems...I am not aware that Mutoh has even admitted the ink issue as of yet.
Is anyone having problems with Mutoh ink cartridges? In the last six months I have had at least ten cartridges where the plastic disc inside the cartridge has come loose (while in the machine) so will not pop out to tell the machine when cartridge is out of ink so machine will continue printing, ruining the print and causing havoc with the machine. Mutoh claims no one else is having this problem which I find really hard to believe.
We are using the 220. We have had huge problems with them. Somehow due to the new cartridges (I believe because they are so weak) the tabs inside the cartridge that is supposed to pop out to let the machine know the ink is out has broken off inside, after installation, so the machine continues to print, ruining the print and draining the lines, mixing colors etc..., It has caused us so many problems. In the last six months we have probably had ten cartridges that were faulty.What carts you are using?220 or 440
strange.usually problems associated with your printer all related to small 110ml size slot so even small 220ml carts extends too much out of the slot making a week contact.even worse when people are trying to use 440 carts ...they simply pointed downwards ,loosing their horizontal balance meaning when cruical ink amount of 40ml left in the cart -which should trigger the switch via lever tab glued to bag- it will never happen coz its located at the tail.check your horizontal level
So... I'm considering buying a used Mutoh Outdoor Jr. Printer, along with quite a bit of equipment, programs, etc. This thread makes me a bit nervous about the printer itself. Is it possible to get quality ink for this? Is it a good printer? (She wants about $7K for the printer, inks, and solvent that she has.)
