Mutoh Inks
Discussion in 'Mutoh' started by MobileImpact, Apr 12, 2007.
  1. MobileImpact
    MobileImpact Active Member
    759
    Whos got the best deal on Eco Solvent Ultra Inks. Also are any Mutoh people using any of the third party inks, either in bulk or cartridge and are you happy with them.
    Thanks,
    Kevin
  2. MobileImpact
    759
    any one?
  3. kirkbedtelyon
    kirkbedtelyon Member
    173
    Nov 28, 2005
    Gaylord, MI
    I've been buying mine through SW. Stocked up when I bought my ValueJet since they give 10% off for 30 days. $59.95/cart. less 10%.
    I haven't seen or heard of any after market Ultra Inks. Have you Goggled it?
    I'd be interested in knowing if its available although I doubt I'd try it unless I heard some good things about it and the price was right.
    KB
  4. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,812
    59
    48
    Feb 27, 2007
    World
    Try Triangle inks
  5. MarCom
    MarCom Member
    28
    Oct 4, 2006
    Michigan
    Try lavaink.com . They've been working very well for me.
  6. MobileImpact
    759
    JUst got the Lava inks in today and plugged in. So far so good.
  7. Gene@mpls
    Gene@mpls Very Active Member
    2,006
    87
    48
    Jun 17, 2003
    Blaine, Mn
    The last time I talked to Triangle they were working on it. When they have
    Mild solvent for the Valuejet I may switch from my VersaCamm- but not before!
  8. creative
    creative Member
    225
  9. Jackpine
    Jackpine Major Contributor
    I used lavaink.com when they were eco solvent plus. They worked good. I was told that the Ultra inks were not compatible with the Plus inks, not so. I think Roland and Mutoh just wanted to get rid or their stock. I am using Ultra inks now and they are very good but the price went up. I get Ultra inks from Gregory. I will try Lavainks again.
  10. rtallent69
    rtallent69 Member
    53
    ink
    roland max ink is the same as mutoh ultra ink if you take apart an empty cart. they have the same little epson sticker and part number. So look for a 3rd party max ink also and it will work the same.
  11. Valentino
    Valentino Active Member
    675
    Jan 16, 2007
    so will the Lava ink work on a valuejet? what about the chip?
    also...how are the color matches to the OEM ink?
  12. Ken
    Ken Major Contributor
    5,484
    2
    38
    Feb 7, 2005
    BC
    Triangle inks.
    Ken
  13. MobileImpact
    759
    I have been running the Lava Ultra inks ($36 a cartridge) I am currently running 3 of these cartridges (black, Magenta and LCyan) with 3 of the Mutoh Ultras. NO problems and prints great.
    Kevin
  14. rtallent69
    rtallent69 Member
    53
    inks
    you keep taking the chip or card of sticker from the oem cart and put it on the 3 party ink. if you llok at mutohs oem cart. on the back side of where they put there ship is a cutout and a screw hole were roland places their chip they are all the same. When i put new ink in i just take the card off of the empty one and put it on the new one.
  15. Valentino
    675
    Jan 16, 2007
    doesn't the chip record that it's empty, similar to epson printers? (like the home models)
  16. Bradster941
    Bradster941 Very Active Member
    2,190
    I wonder about this also.
    How do you defeat the chip if you wish to refill your carts, or use third party carts ?
  17. rtallent69
    rtallent69 Member
    53
    inks
    they are dummy chips they just tell it that it has ink or has a cleaning cart but not levels pull your cart out and put it back in and it will show full again
  18. Valentino
    675
    Jan 16, 2007
    I had a phone call with a mutoh tech from the mutoh HQ and he said that the chips do hold memory of how many fires and cleanings the cartridge went through.
    so I will stick to mutoh cartridges.
