Mutoh Printer problem any ideas
OPTIMA GRAPHICS
Hello been having problem with my faclon outdoor printer. No ink was coming out on the nozzle check so i was advised to replace the print head fuses. and i also replaced the print head cables.. I uncharged the machine before i worked on it. Now when i go to print the nozzle check it stops 2" from the home position and the machine just turns itself off. I have to unplug the power supply and plug it back it for the machine to power up. Any ideas on what i can do to fix this???? It never had this problem before i replace the print head fuses and cables
jwright350
will it still run a cleaning cycle? if it can do that then its possibly not print head related... is there ink in the dampers?
OPTIMA GRAPHICS
power down problem
there is inkn in the damper but when i do the nozzle check it powers off 2 inches into the nozzle check patter. then i have to unplug the maching and plug it back in to get it to power back on and then it does the same thing.
