Mutoh Pump Life Times
guitarguy69
Power the machine off, hold + - and right buttons down and power up holding until the initialize screen displays then it will read Check 1: Adj. Platen. You can then let up on the buttons and scroll > to Check 8: Parameter, ENTER, should read Param1: Initialize, ENTER, > to Init. 8: Pump, ENTER, Initialize ok?, ENTER. Cancel out and power off then on.
Good Luck
Brian
randya
Brian is correct.
But, Please use caution in Maintenance Mode.
Dont make make random changes in areas you dont understand.
You can cause issues with your printer and possibly disable it.
bendeane
Pump Life Times reset...
If I reset this without replacing the pump, is that "bad"? How do I know my pump is really in need of replacement?
This is not a direct correlation, but I've had office printers that tell me my toner is out and then when I do a toner reset, i get 2,000 more pages on the cartridge...is this a way for Mutoh to get you to buy parts prematurely?
Thoughts?
Suggestions?
CheapVehicleWrap
Thoughts?
Suggestions?
It's basically a timer & no doubt in Mutohs favor. I'd get another sometime soon to have on-hand though.
randya
It is based on Mean Time Between Failures.
It does not disable the machine, but lets you prepare for estimated replacement of said part on your own time.
