907customs
I recently moved my 38" mutoh to another location a couple hundred miles away. Prior to doing this, I ran a solvent flush through it. The printer sat for a month, and when I tried to get it up and running, nothing but problems. Here's what I've found so far... I'm getting NO ink into the dampers...any of them. I disconnected the ink lines at the dampers, and pulled vacuum on all of them, and now have ink to the dampers, but not in the dampers. I pulled vacuum on the discharge lines to the waste ink bottle, and can pull solvent, or ink from the maintenance station, but only with the print heads off of the station. When print head is on the station, it will pull nothing. So, where do I start??? New print heads? New Dampers? New maintenance station? All of the above??? Thanks in advance for any help.
