Mutoh SP3065 diagnostic code
zopylote
Hey fellows i just bought a Mutoh Spitfire 65" (SP3065) i'm not familiarized with this plotters and i stared to change two printheads and change the color order because went bad (YYCCMMYY) and needs to be KYCMMCYK i will use bulk ink system
the problem comes when i entered to some configuration and by error erased al data, after that the plotter starts and when i want to print says E066 - CR Motor Err
i check encoder, motors axis and all is ok
i can acces to two menus, one with F1+F3+UP key and the other F2+F4+DAWN key, but when i want to acces to UP-F1-DAWN and askme the code (thought 0393) is not working
or if some one knows about restart this machine i really will appreciate it
i think that i need to set
- the Y motor and encoder CF
- Media Sensor sensivity adjustment
i have only the operation manual and service manual but looks like i need to find another manual...
i will give you a free beer LOL thanks for help me and read my concern (baaad english maybe too)
wunder
The 0393 Special Code only funktion by older Firmware 2.11 or 2.19
The Colorconfig must be KKCCMMYY OneColorOneHead !!!
The trouble with the error can be the Head Driver Assy "is on Top Mainboard plug
regards
wunder
and now my beer ;-) cheers : Toasten:
zopylote
regards
wunder
thanks for your tips, i checked all and everything looks good, i went to adjustment and test and al parameters goes well, i read all again and configure the mainboard to 65" and initialized all parameters again and works!
now i have problems to adjust the media sensivity sensor the values that says are 223 to 216 with media and 48 to 0 without media, i set in the parameters and not want to recognize white gloss media, do you know if i need to do something else?
thx for your help
zopylote
done! the plotter is working right now and all the error was because i erased all and i need to initialized all the parameters...
i working with 3 printheads 8two new and one used) i hope buy the other one next few weeks...
