zopylote
Hi everyone I had working on an old spitfire 65 and after a couple of prints and turned off then on the error appears
-System Error E103 Fuse 2 Error
this is a Fuse error for the printhead no. 2 can be a bad cable and the fuse in the mainboard blown out
I already checked fuses and all are ok, unfortunately one triac was bad from the bank 2, I checked all triacs and changed the bad one C4131
After changing the triac and verify all the values in all the triacs I turned on the printer again and the error still there:
No fuse blown out, all triac A1746/C4131 are correct, all cables are correct, printheads correct (already changed one for other and so), ph replaced...
What I missing? do someone had a similar problem?
