Mutoh ultima
msenjur
how can i set that the cutter will make cut-off 1cm after plot (when i'm performing print&cut function). I'm using auto-align function, with 5mm frame. And cutter always cut-off 2cm after black line! i have tried page mode, sheet-off margins, in software (easysign) Start point behind the plot... nothing! it take no effect!
Thanks!
R08
Had the same problem... fixed it but can't remember how. If it comes to me I will repost
BTW welcome
Paul Schoofs
From plotting dialog, click "Edit" button, choose "Plot options", select "start point behind plot" and "Cut vinyl after plotting". I've tested it and works fine with EasySIGN version 5.
msenjur
hello...
after a while...
that edit plot options doesn't work for me! i don't even know what funcionallity it has! no mather what i type in, always is the same...
