Need Help mutoh value jet 1624 print issue
kamenbraykov
Hi guys
I'm having a print issue with our VJ1624 - perfect nozzle check but it has shadow print on the black colour only
I thought it may be from the encoders so change them both but no luck at all :(
VJ-1624 PF ENC Scale
VJ-1624 encoder strip
Head alignment looks good
Any ideas?
Kamen
Are you sure the head alignment looks good? That looks like classic bad bi-directional alignment.
Edit: Actually on a close look it looks like you may have some electrical issue going on. I would check your head cables and make sure they are clean and not damaged. That's a good place to start. Unfortunately, it could be the head failing as well.
kamenbraykov
Will check the cables now - I've got spare set :)
An engineer did some alignment and it is now printing like this
Is it possible to do this bi-di alignment by my self
Thanks in advance :)
There are a lot of bi-directional alignments you can do but the one that will tell you the most is the one in the user menu. Go to Menu>Setup>User Type>Adjust Print. You can print the rough pattern and adjust it and then print the fine pattern and adjust that. Then run a print and see how it goes.
kamenbraykov
We did this print adj to all patterns it looks fine to me a bit better but still doubles vertical lines - vertical issue only
kamenbraykov
this is what I've got so far - hopefully is not the head
all those photos with mag. glass
