Need Help Mutoh VJ1324 printhead/cap top adjustment
Netter26
Hello. I just replaced a couple dampers and all of my O-Rings. All four dampers have been replaced within the last 2 weeks. Now I can’t get any ink to move at all. The printhead will fire part of the blue and yellow nozzle check. But with doing a little charge and cleaning I still get no movement. My Maintenance station is 2 months old and I swapped out my cap top too and still nothing.
When I pull through the drain tubes with one closed off there’s no resistance. So I assume the head not making a good seal with the cap top. Is there any way to adjust the printhead or cap top? Or any other advice to get the ink moving would be appreciated.
thank you
hand851
Roland Mutoh & Mimaki inks digiprint-parts.com
Try this.
  • 1324 Cap Adjust.pdf
