I had a problem with the head missing nozzles and did what I normally would do to fix. A thorough cleaning and then worse case putting solution in the capping station then running a cleaning when it has been bad before and it fixed it. This time i had a problem with the Maintenance station so I replaced it (2nd one i have replace) and when powering back on it gave me a E068 Err CR Encoder.
so at this point this is what I have replaced-
1.Encoder & Strip - Still same error. Got Mutoh on the phone and they verified with me the encoder and strip are reading correctly.
2 Replaced the motor - power back on and still the same error.
What can I do now to get this printer up and going because these are the items mutoh went thru and said replace? Need help bad. Going on 2 weeks we have been down!
