Aright, so we have a mutoh VJ-1614 that we've had for several years now. We have stopped using it as much as we used to since we travel a lot now. We kept it plugged in and had the auto clean feature setup to do a head clean to keep it from clogging. The problem is while we were out of town, the girl who cleans unplugged it to move it and forgot to plug it back in. Since then it has sat for about 5 months without being used. The my employers finally got around to buying some things I needed to get it fixed. Of course the head was clogged so I pulled the head and cleaned it. I Finally got it unclogged after about 8 hours of trying to suck cleaning solution through and trying to get it to spray from the head. I've replaced all the dampers and i've even used a syringe to suck ink through the lines so I don't think they are clogged. So When I put everything back together, no ink is getting pushed through the lines. I've run several cleanings and tried a ink charge all with no luck. There are no errors on the screen except pump life times. I read here on the forums that the pumps life message won't actually make it stop functioning.
So, I'm stuck scratching my head and I don't know what else to try. Any ideas on what would be causing the ink to not be pushed through the lines? (btw, I did leave it with cleaner in the head until i can figure out what the problem is.)
