Twisted Grafix
I recently replaced all 4 dampers in my 628.  I cannot get the ink to pull and fill them with a syringe, with a little charge, or initial ink charge.  The cap top is about a month old.  New o-rings were put in with the dampers.  I double checked the lines at the bottom of the cap to make sure they are in the correct position and that the seal around the head is good.  I can get a vacuum with the syringe, but not enough to pull the ink all of the way through.  I've pulled ink through the lines to the dampers, and connected them and the ink is still to that point, so I don't believe I have any significant air leaks, if any. Does anyone have any thoughts as to get this thing back up and running?
