Mutoh xpertjet 661uf . Need help which ink needed and the difference between US11-UV- Ink and UH21-UV ink
gitec01
Please if someone can help me regarding the ink Mutoh XpertJEt 661UF. what the difference between the US11-UV Ink and UH21-UV ink? which one you'll suggest. i'll be printing in Acrylic Sheet, Wine Glass using DTF Film and some lighted signs?
Thank you in advance
Ronny Axelsson
I switched from UH21 to US11 on my VJ-626UF a couple of years ago.
The UH21 ink was great in many ways, the colors were very good and the details I could produce were amazing.
I very soon found though that the ink was extremely rigid and brittle, and it also continued to harden when exposed to sunlight which made stickers crack and curl if applied outdoors.
The flexible US11 ink is better and obviously more flexible, but unfortunately it exhibits the same problem when exposed to sunlight for a longer period, it becomes harder over time and breaks.
US11 is not as scratch proof and not as solvent resistant as the UH21 ink, but it is softer and has a rather nice semi matte and smooth surface that I like.
The color space is also a little more limited than the rigid ink, but I can live with it.
I can not say whether the US21 ink will be suitable for your needs or not, and I suggest you talk to a Mutoh reseller.
Maybe they can provide you some samples?
gitec01
Thank you for the help.
Santimus
Member
In your opinion is neither ink set suitable for long lasting exterior signs?
Ronny Axelsson
Unfortunately I can not recommend either of them for outdoor use.
Stickers show the same tendencies when exposed to sunlight, even though it may be slightly better than UH21.
Colors also fade more than I expected (hoped for) so I suggest a layer of varnish to make it better, but it was the same with UH21.
Conclusion: The US11 ink is great for indoor use, also on soft materials, and it works fine for short/medium term outdoor signs.
Add varnish or a laminate to increase UV resistance.
Also, make sure you have enough jobs to keep it running, it consumes quite a lot of ink for cleaning when not in use (especially white and varnish) and the ink is ridiculously expensive.
