Need Help my computer gives me "printer install FAIL" window when I try to install
Discussion in 'Installation Equipment & Techniques' started by dirttoo, Jun 23, 2019.
  1. dirttoo
    dirttoo Member
    86
    Feb 27, 2010
    Illinois
    I bought a new Rogue cutter (probably a mistake) from Signwarehouse (another mistake) and I'm having trouble with installing the cutter. The instructions they give are very generic and are not working for me. I get into it a ways and it says to right click on 64bit and select "run as administrator" but that option is not there, they say it is but it is not. I try going on with install but end up with "printer install FAIL" I have tried several times with the same outcome. I have called Signwarehouse every day for the last week and get a big runaround. "Tech is closed and they will call you tomorrow" but the never call. I heard that every day this last week. Apparently they don't care if I just send it back. Can anybody suggest anything to help get me cutting? Thanks
  2. FrankW
    FrankW Very Active Member
    1,324
    135
    63
    Oct 19, 2008
    Germany
    What operating system do you use?
  3. WildWestDesigns
    WildWestDesigns Major Contributor
    6,618
    334
    83
    Sep 27, 2010
    5
    EDIT: NM, I see that you did.
    Is the account that you are in have admin rights? If it doesn't, that option shouldn't be there.
    Only other thing, while the instructions say to click on 64 bit, is your OS a 64 bit OS?
    • Agree Agree x 1
  4. dirttoo
    dirttoo Member
    86
    Feb 27, 2010
    Illinois
    How do I know if I have admin rights? I assumed I did
    My computer is 64bit
  5. WildWestDesigns
    6,618
    334
    83
    Sep 27, 2010
    5
    Well, the easiest method is if you only have 1 account on a Windows machine that means that it's an admin account.
    Typically, if you aren't an admin, it should prompt for the admin password (hopefully there is one, most unfortunately don't, especially if you only have 1 account on the computer (something that I personally wouldn't have on a Windows box, but I digress big time)), especially when installers come into the picture (or at least it should).
    Especially if you are in an admin account, "run as admin" should be a right click option.
  6. unclebun
    unclebun Very Active Member
    Even if you computer is 64 bit, Windows may not be. Make sure your Windows is 64 bit.
    What version of Windows are you using? Do you have a compatible version of the driver installer, i.e. Windows 7 driver for Windows 7, Windows 10 driver for Windows 10?
  7. dirttoo
    dirttoo Member
    86
    Feb 27, 2010
    Illinois
    Got it figured out. Thanks guys
