My magenta and yellow are not printing
Discussion in 'Roland' started by CENTERVILLE SIGNS, Jul 14, 2020.
  1. CENTERVILLE SIGNS
    CENTERVILLE SIGNS Member
    187
    2
    18
    Dec 19, 2011
    Nutley, NJ
    Versacamm SP-300 PLEASE HELP
  2. Solventinkjet
    Solventinkjet DIY Printer Fixing Guide
    4,237
    796
    113
    Aug 2, 2011
    Denver, CO
    Yellow and magenta are on the same head and protected by the same fuse. If they just dropped out completely out of the blue, that's probably the issue. Check your head cables to make sure they aren't dirty or damaged. If they are, replace them. Then replace the fuse. It's a 1.6 amp fuse and, depending on the age of the machine, it's user replaceable but might need to be soldered if it's an older version.
    • Agree Agree x 2
  3. Jim Hancock
    Jim Hancock Member
    435
    73
    28
    Nov 11, 2008
    Delray Beach, Florida
    Please attach a nozzle test print. If you have absolutely nothing on the magenta/yellow head, as said by solventinkjet, then a blown fuse for sure. Besides the cables, it could be a shorted transistor on the head board or a bad head. Did anything happen before the channel loss, such as a head strike? If you know how to use a resistance meter, I can guide you through checking the fuses and transistors.
    • Agree Agree x 1
  4. Jester1167
    Jester1167 Premium Subscriber
    Did it happen overnight? If so it could be your capping station. If it happened during the day after a successful print try the fuse.
  5. greysquirrel
    greysquirrel Active Member
    594
    82
    28
    Aug 13, 2015
    West Berlin, NJ
    check fuse, replace cap top, replace head, replace main board...in that order
  6. BOKAMOSO
    BOKAMOSO CREATIVITY AND INNOVATION
    1
    Jul 13, 2020
    Gaborone
    Try to do powerful cleaning and test print, if nothing happens, it will require technical maintenance
  7. netsol
    netsol Active Member
    842
    122
    43
    Apr 26, 2016
    englishtown, nj
    centerville
    we are also in new jersey
    do younwant me to ups you a meter and some test leads?
  8. jfiscus
    jfiscus Map Wraster
    3,202
    241
    63
    Apr 2, 2009
    Cincinnati, OH
    Take the cover off the capping station
    Park the heads on the caps
    Pull the line coming from the caps to the pump
    Apply suction to that line with a syringe until you see ink
    Do a test print
