My Roland is drunk.
Elwood Moose
Apparently my VersaCamm 540 has been drinking.
I am cutting simple ovals out for a decal run. The cuts on the right side of the bed are bang on perfect, but by the time the cuts are being made on the left, they are off kilter.
The cuts on the left hand side are cutting mighty close to my artwork, despite the fact that it is a single image that VersaWorks has duplicated itself, so is the same file as the artwork on the right hand side.
I have cleaned the data strip, and the machine is running fine other than that. I also run an enviromental match befor eall my cut/print jobs, so I'm certain it is not that.
The decals run 12 across, and the problem get slightly worse each decal.
TresL
Call Roland, they have a PDF to help with alignment if needed.
Mine would do that when doing a print then cut.
But, when using the dot alignment, I had no issues.
