My Seal is Broken! Please help!
jaybeeb
Hi Guys, suddenly on our Base 54 the forward/backward and snail buttons have to effect.. the safety lamp indicates no problem.
I checked the fuses (2) next to the breaker they were fine. I also check 5 fuses that are under the circuit board at the top. no problem there either..
Am I missing a fuse or something?
Thanks!!
jaybeeb
OK, I feel like an idiot.
Found the problem, one of the staff hit the emergency stop without knowing it. And I didn't know that those had to be manually reset in the up position.
Wow that was pretty stressful for a Monday morning.
omgsideburns
You're not the first.. lol.
Also, on my GBC, if the feed platen pin isn't push far enough over it will only run when the foot switch is held. That one still gets me sometimes.
stickerman12
Just tried my first job on out new Ustech this morning and couldnt figure out how to turn it on. Checked fuses and plug. You guessed it!
