Need A Flexi Walk Through For 8.5
Discussion in 'Flexi' started by vectorterrorist, Jan 26, 2009.
  1. vectorterrorist
    vectorterrorist Member
    152
    Hi, I am trying to make a set of mx graphics. I have flexi 8.5 as myprint and rip program and I am new to large format printing.
    I wanted to see if anyone would be kid enough to give me a step by step walk through how to use flexi to print and then cut the graphics.
    When I design the graphics I have a layer for the actual design and then a layer above which I want to use for the cut line.
    what I would like to do is to import both of these layers into flexi (keeping them seperate layers) and being able to tell the printer to print just layer one..and then have the plotter cut just layer 2.
    Is this possible? Like I said I am new to using flexi but really would like t learn how to do this.
    If this is the wrong steps..can anyone tell me what the right way to use felci to print the graphics then cut them would be??
    Thanks in advance
  2. thewood
    thewood Very Active Member
    1,781
    Dec 28, 2005
    Tennessee
    In what software are you designing the art? You should be able to import you art in to Flexi, select the layer you wish to be the cutline, and use Effects>Contour Cut. RIP and print as usual. The printer will print the appropriate crop marks, etc.
  3. vectorterrorist
    152
    I tried that..I imported a rear fender but when I go to effects then contour cut...it want to cut as a square around the fender..not follow the contour of the fender.
  4. DRPSignsNGrafix
    DRPSignsNGrafix Very Active Member
    U need the countour of the fender seperate as a vector then u can make it a contour cut line
  5. LittleSnakey
    LittleSnakey Member
    384
    When you bring something in from illistrator into flexi you will first have to ungroup it. Then most likely you will have to unmask the object. once this is done you will be able to see all the items in the design editor. Find the path that you want for the cut line, select it then goto the arrange pulldown menu, contour cut, make contour cut.
    Good luck, I hate using Illistrator files in flexi, alot of times I will save them as a high res jpg file and bring it into flexi like that and export the cut line as a older version eps file and bring that into flexi separately.
    Hope this helps
Similar Threads - Need Flexi Walk
  1. LittleEG
    5
    420
  2. BluetailGFX
    Need Help Software Help Again.... Need FLEXI File Opened
    2
    752
  3. B13 Signs
    6
    1,018
  4. buggyjr12
    8
    875
  5. paxas
    846
