need a good company to make my design into a vector format
Discussion in 'Flexi' started by signdesign, Mar 11, 2005.
  1. signdesign
    signdesign Member
    151
    Does anyone have a great place that does wonderful work to change a design into a vector format for eps flexi. I have a design a company wants somes signs from but it would take me way to long to scan and clean up. Please reply soon. Thanks
    Karen
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,921
    545
    113
    Sep 11, 2003
    Olympia, WA
  3. Grady
    Grady Member
    52
    can you post a picture of the design so i can take a look at it?
  4. Applied Graphics
    Applied Graphics Member
    40
    I just sent two files to Viking to convert yesterday and had them back this morning. They were great! I would highly reccommend them.
    Steve Shearer
    Applied Graphics
    Cody, Wyoming
  5. signdesign
    signdesign Member
    151
    program
    Isn't there a program out there where you can scan a picture in and click vectorize it and it comes out perfect no touching up. That would be awesome. Anyone know of any. I ended up sending it over to vikingart to see what they say.
    karen
  6. WVB
    WVB Very Active Member
    2,749
    No, there is no program that is perfect. You can use Flexi and tweak form within or export to Illustrator and use path/simplify and tweak from there. Adobe Streamline is another.
  7. Fred Weiss
    20,921
    545
    113
    Sep 11, 2003
    Olympia, WA
    To get nearly perfect results with black and white artwork, you need Photoshop and Streamline. You scan a high quality image at very high rez (Vikings Arts specializes in vectorizing low rez poor quality images) so you end up with a large black and white at 300 DPI which looks great. Then you autotrace it in Streamline.
    Despite all the advertising to the contrary, there is no single solution for acceptable or better results in autotracing applications. As with most things, the more skill, experience and tools you have, the better the job you can do. Acquiring the right tools to handle most autotracing needs along with adequate editing and touch up tools runs up into the several thousands of dollars, lots of time learning and practicing, and the occasional job that can only be done by hand tracing.
    You also need to get good at identifying type because not autotracing application out there will capture the subtleties of type faces.
    You can get a lot of work done by Viking Arts for what you would need to put forth to never have to hand trace and get good results autotracing.
  8. Yep! Doesn't your computer have an "EASY' button? Mine does! Boy! Is it sweet! :)
  9. signdesign
    signdesign Member
    151
    how much to for the easy button
    How much to install that easy button. :Cool 2:
  10. Graphic Language
    Graphic Language Member
    203
    Right next to the Any key on mine.:wine-smi:
    Bryce
  11. you must have a newer keyboard than mine, don't have one of those! :wink:
  12. Fred Weiss
    20,921
    545
    113
    Sep 11, 2003
    Olympia, WA
    [​IMG] Take it from the Big Guy. It used to be called Delete but it is now used for the easy cleanup feature as well. Just Select All and press Delete if you don't have an Easy key.
  13. jimdes
    jimdes Active Member
    997
    2
    A little off the subject, but I still have my "Panic Button" on my keyboard from the late eighties. Originally installed on my Amiga 2000, I'd like to find a new one because this one is barely legible anymore.
  14. Bobby H
    Bobby H Very Active Member
    2,259
    204
    63
    Feb 4, 2005
    Lawton, OK
    Autotracing functions in Adobe Streamline or Flexi and others are okay for rough comp purposes, but little else. If you want well vectorized stuff, nothing outperforms vectorizing by hand.
    My tool of choice for any auto tracing functions is a two step process in Adobe Photoshop. Use the the Color Range function to develop a selection on a high rez scan (adjust the fuzziness slider to tweak the result). Once the resulting selection is made, open the paths palette and select "make work path". Adjust the pixel tolerance and hit OK.
    Granted, this method is not absolutely perfect, but I often get more satisfactory results than what I achieve with Streamline. The big advantage is all your paths are closed loops. Streamline tends to create all sorts of open path trash.
    For doing things the hard way (manually vectorizing), I use a combination of Photoshop's pen tool functions and CorelDRAW. Photoshop's pen tool and keyboard shortcuts make accurately digitizing "organic" elements a relatively fast process. At least it is far faster than trying to do the same thing in Corel, Illustrator or Freehand. I'll defer to Corel when digitizing more technical things where paths have to fall on certain geometric alignments. Out of the three drawing apps Corel is by far the best for this since its on screen preview is much faster than Illustrator or Freehand.
  15. Fred Weiss
    20,921
    545
    113
    Sep 11, 2003
    Olympia, WA
    I get excellent results from Streamline without anything in the way of open shapes ... but I first do a thorough cleanup in Photoshop. To accomplish this I recorded some actions and assigned them to function keys.
    Basically the way they work is I scan at a very high resolution so that I end up with an image in the range of 6000 pixels tall or wide. The image is moved to it's own layer.
    Next all non-image parts of the scan are selected with the magic wand and the first action is run. This action expands the selection by 3 to 5 pixels (depending on the edge quality of the original art), smooths the selection by two pixels and then deletes whatever pixels are within the selection.
    The second action selects the artwork on its layer and expands the selection by 3 to 5 pixels, smooths the selection and fills the selection with 100% black.
    The overall effect is a nice smooth and well defined edge which Streamline loves.
    Flatten the layers, save as TIF and you're ready to trace it in Streamline.
