edsullivan1
Looking to buy a new design computer for general sign making using Corel, Adobe products and Flexi. I was looking at a SignBurst Inferno, any other suggestions?
Very tempting to go PC and save a couple grand.
Adobe just seems to run better on mac.
For what it's worth, I've built several PC's for our own design use. If I were to do it over I would use a third party just to save time and aggravation getting everything optimized. Probably the most common misconception would be to focus on a graphics card. Unless you plan on doing heavy 3D work, you just need a modern, basic card with stable drivers (such as NVidia workstation cards or their consumer grade counterparts) that have the correct outputs for your planned monitor setup. Adobe CS and Corel etc. are 2D programs which place a premium on the processor (Multi core) and memory cache. Also the write speed of your disc system will influence performance so an SSD or msata setup to run applications and as a 'scratch disc' will improve performance. One of our design stations serves as a file server so I have that set up with a four disc RAID 10, but that is probably my over-abundance of caution since RAID is no replacement for our onsite and cloud backup plan for seven years worth of design files. I felt our money best spent on decent monitors and color calibration.Looking to buy a new design computer for general sign making using Corel, Adobe products and Flexi. I was looking at a SignBurst Inferno, any other suggestions?
With todays modern 64bit systems and software, the more RAM the merrier.
As mentioned - the vdeo card is really not all that important for what we do. You do NOT need the latest and greatest 3D gaming card.
To me, this is going to depend on the components. I run a Lenova ThinkStation with Xeon Processor and 32 GB ECC Ram. I virtualize all my Windows needs. Nothing of Windows runs on bare metal. In that case, it's just 16GBs of RAM (although I can run more as my host OS uses the XFCE DE). It runs better in a virtualized environment then it did on bare metal with the same amount of ram just on the higher end consumer side. I can still render video and animation in a VM and that's usually a big no-no in a virtualized environment.
I would say video cards are important, just have to get the ones that fit the needs. Like you said gaming cards aren't it.
Just got a crazy setup Imac Pro. 10 core processor, 128 gb ram, 64gb graphics, SSD, etc. Spent almost 10 grand on it. It's better for sure but not as good as I would have hoped. Most files I work on are 2-6 gb and I'm not designing. I'm just prepping for print so a lot of cropping, mirroring, saving, etc.
