Can you make your own? We have made a lot of these. 26GA cold rolled steel (cheap) adhered to 1/4" PVC with print and dry erase laminate on top, really great for custom sizes!
How do you fix your steel to PVC? I imagine you install the print directly on the steel?
Yes....mount the print to steel just like you would any other sign.
We use a double sided tape to mount the finished steel to PVC. It's a 30" roll....looks like laminate. Peel one side, apply to steel in laminator. Then peel the second sheet off and mount to PVC.
