Need advice on forming letters
biggmann
I was "thrown" into making the channel letters for our shop, I have the backs routed and using .040 (I believe) for he returns. Now I have no problems making the right angle letters "E", "T", "I" etc. Now the problem is rounding the curved letters like "R" "S", what is the trick to doing these? I have three different size pipes to form the aluminium around but not all letters are just a curve, the R I am working on curves then goes straight for a slight piece then curves again, I cannot for the life of me get this curve right. Is there a trick to this or just time to get it right. Any advice is greatly appreciated.
I have also seen different types online that use acrylic for the returns or very thin aluminium instead of the thicker aluminium I am using now, are those kits any good?
Moze
Precision Sign Services
In my opinion, it's not really something you can learn on a forum. You really need to work alongside someone that can teach you the trade. Or just be prepared to go through a ton of trial and error until you get it right.
.040" isn't considered thick. Most competitive quality sign shops use at least .040" on returns, .063" for larger letters.
MikePro
rolling, not just bending, it over different-sized pvc pipes usually does the trick for me. kind-of like how you can't simply wind balloon ribbons around a pencil, to make them spring-y, but scraping a blade against it suggenly makes it want to curl like a fat-guy in the olympics.
we also have a few hand-crank steel rollers that start the curve, and the rest is tweaked by-hand.
tools&tricks, but ultimately a HUGE +1 to it being an experience that just comes with the trade....
biggmann
I am trying to gt someone in here to show how to do these things, not much luck. It is going to be a lot of trial and error. Right now if I could afford it one of those auto benders you see at the sign show is looking pretty good.
AceSignsOnline
Sorry to hear you're having such a tough time. As for the auto-benders, they are great and all, but they pose a whole new set of problems. I know that if they were truly automated and actually did what they were advertised to do, our production would be at least triple what it is now.
Wish I had some profound wisdom to bestow upon you. Have you tried looking up some videos on YouTube? I know that even watching our automated bender has been invaluable in grasping the concept of how things would be done by hand.
