Need advice on translucent vinyl
ProWraps
long story short, we are leasing a 4.5' x 14' sign right on the freeway for a year with option to renew. its a backlit box with acrylic face.
i saw that translucent vinyl is pricey to the tune of $2.00+ per sq/ft but solvent printable as low as .44 cents per sq/ft for a solvex removable 1 year outdoor translucent.
we will change the message quite often, at least every month or two.
can someone with experience tell me if printing the solvex and doing a contour cut would work and not look bad?
its going to be just text and even though its right on the freeway with no obstructions, its still a good 50' feet away.
we were going to do two simple lines of text, no logos.
thanks a bunch in advance.
-chris
speedmedia
for what it's worth I have done this a couple of times with ok results. You could always pick up a roll of clear and print your message with an overprint. If it is short term you could just use some calendared stuff and swap it out often.
Thanks,
Kurt
