Need advice quickly... Re: One Shot and Clear Coating with Mathews Clear
Discussion in 'Hand Made Signs' started by tebond, May 3, 2013.
  1. tebond
    tebond New Member
    22
    Apr 22, 2011
    Cincinnati
    I sprayed a two panel sign with Mathews Brilliant Gold Metallic with catalyst and reducer, then I clear coated with Mathews (catalyst and reducer), I let the Clear cure 36 hours and then masked and lettered the sign panels. Evidently the clear had not cured completely and the mask dulled the finish some but more noticeable are tape marks in the clear where I taped up large areas to be painted with the One Shot. The One Shot Enamel is a mixed blue with a little One Shot Hardener. I have had the panels after lettering curing up in the sun for two days now in the hopes I may be able to Re-spray Mathews clear to remedy this situation. It is now Friday night and I have to deliver the signs Tuesday. Is there a way I can spray Mathews Clear to conceal the tape marks. Or any suggestions how to conceal these marks easily.
  2. visual800
    visual800 Very Active Member
    3,930
    267
    83
    Aug 4, 2010
    montgomery, alabama
    I would mist the next clear and then a heavier coat. Put it on too thick and it might be too hot and jack everything up. The clear should conceal all issues
  3. SuncitySigns
    SuncitySigns Member
    168
    Why don't you just coat n push the clear we're it's dulled. Same theory as cutting n polishing a car when the clear coat has dulled over the years.
  4. tebond
    tebond New Member
    22
    Apr 22, 2011
    Cincinnati
    Another question before I do this
    What about sanding first so the clear would hold. Would a very light wet sand with 1500 grit be sufficient, like just a quick wipe as to not to damage the lettering. The clear and push, what's that.
  5. Craig Sjoquist
    Craig Sjoquist Major Contributor
    6,746
    4
    38
    Jun 18, 2004
    Orlando
    Tebo .. You mentioned added harder .. So just like PHD said mist 1st coat clear heavier 2nd & yes a light wet sand is even better.
    You will be fine adding harder helps prevents other paints & clears of harming 1 Shot.
    Wet sanding will give the clear some tooth to bite & smoother surface.
    Clears will camouflage surface strangeness.
  6. Billct2
    Billct2 Major Contributor
    7,483
    650
    113
    Mar 12, 2005
    New England
    Agree & good luck
  7. tebond
    tebond New Member
    22
    Apr 22, 2011
    Cincinnati
    Thanks for the input, am headed to the shop to light wet sand, mist and then I'll wait about 20-30 minutes and put the wet coat on, sure hope it will cure up by Tuesday early afternoon. I'll check for any more info in about an hour.
  8. John Butto
    John Butto Very Active Member
    2,310
    3
    38
    Jan 9, 2007
    read...
    Is this what you are spraying if so it dries within 24 hours.
  9. Jillbeans
    Jillbeans Major Contributor
    14,457
    19
    38
    Dec 24, 2003
    Butler, PA
    Just be careful, I have had 1Shot crinkle like crazy after spraying it with clear (even their own aerosol clear)
    Love....Jill
