Bogie
Well, I can tell you that everything I've done before is too high - not drying all that fast. If you're running glossy photo paper, what do you set it at? Using a generic profile for the paper from Intellicoat, but POS Photoprint defaults to 100 across the board... Started out at 85 (where I normally run vinyl for signs), and I'm down to 40... How low should I go? Figured that HAD to be low enough, and went to bed last night - woke up, the basket was stuck together...
Heat's at 50 across the board. Cut time is 5 minutes.
