need help identifying a part
Discussion in 'Graphtec' started by Commando, Sep 21, 2020.
  1. Commando
    Commando Member
    256
    7
    18
    Oct 11, 2013
    Tennessee
    Got the 8600 plotter and i think i need to replace the bar that goes through the rollers. I just dont know what its called to find the part number.
    Its drooping for some odd reason. I think its why my rollers wont stay put.
  2. karst41
    karst41 Member
    146
    25
    28
    Nov 3, 2010
    Stone Mountain, GA
    Have you adjusted the Levers on each roller?
    They are adjustable for thick substrates.
  3. Commando
    Commando Member
    256
    7
    18
    Oct 11, 2013
    Tennessee
    Everything is normal except that bar. Its drooping in the middle pretty bad. My other one doesnt do that and it doesnt have the roller problem.
    If you look at the bar from the front, in the middle of the bar, you can see distance between it and the plotter. That isnt supposed to happen.
  4. jwlllpl
    jwlllpl Member
    196
    41
    28
    May 6, 2016
    Florida
    • Like Like x 1
  5. stxrmxn
    stxrmxn Member
    80
    7
    8
    Jan 24, 2014
    Brisbane
    If you find the part number or where to get one can you let us know, i need one of those exact same things also.
    Thanks.
  6. Commando
    Commando Member
    256
    7
    18
    Oct 11, 2013
    Tennessee
    Thanks to jwlllpljwlllpl I contacted wide image solutions. It was 147 for the part as they would have to dismantle a unit for it.
    I took that as, you cant just buy the rail. That would also explain why jw said it didnt have a part number.
  7. Commando
    Commando Member
    256
    7
    18
    Oct 11, 2013
    Tennessee
    I have considered just trying to straighten it but it seems even a couple degrees off would affect the rollers.
  8. jwlllpl
    jwlllpl Member
    196
    41
    28
    May 6, 2016
    Florida
    Just a thought...maybe a local machinist can straighten it or for the matter make a new one.
  9. stxrmxn
    stxrmxn Member
    80
    7
    8
    Jan 24, 2014
    Brisbane
    I found a 3 metre length of 8mm x 8mm key steel on e bay for $13 i am going to try that.
    • Like Like x 2
  10. Commando
    Commando Member
    256
    7
    18
    Oct 11, 2013
    Tennessee
    Let me know, please.
