Need help identifying molded brick-look 4x8 plastic sheets
SignPros
So I've called Grimco, and Glantz as well as a couple of other suppliers, and none of them have any idea what I'm talking about. I've forwarded all of them these same pictures. This product was used on a pylon sign locally that one of my customers want to replicate. The existing sign was built about 6 years ago by a semi-local competitor, so they're obviously not gonna give up their source. Even suppliers I've found that have formed plastic bricks kits, they have to have separate corner pieces, and the sizes are only 2'x4', and they interlock with other pieces, etc. Nobody has anything like this in a 4x8 sheet.
It's a molded plastic sheet. Three-dimensional an looks from five feet away like real brick. Even the edges, as you can see, are molded. It's not a 'system', per se, as they've essentially built a scaffold inside out of angle aluminum and attached it to their posts, and then these brick sheets are screwed onto that frame work.
Somebody please help me out here. This is a job I could start on next week if I can only find some sort of material. My customer would be fine with a stone look, or even stucco.
Thanks in advance for any help.
