Need help to resuscitate a HS-15+ plotter
Discussion in 'Gerber' started by RG, Aug 22, 2012.
  1. RG
    RG Member
    490
    11
    18
    Dec 6, 2006
    South Mississippi
    Yes, I bought it used & untested. It probably belongs in a museum, but I'm trying to give it one, last shot at life. When I first unpacked it, cleaned it up, and oiled it, it worked sometimes. When I powered it up, it went through its start up routine just as it should. Maybe 2 out of 10 tries it would cut OK. The other 8 times it would do nothing--the production manager in Flexi would seem to freeze and say "cutting 0". Once in a while it would give the error message #19 (Illegal plot data command). I thought maybe something had jarred loose in shipping. So, I took off some covers and checked connections. When I powered it up again, I get the error message #5 (Power relay open) and it won't do anything. Can anyone give me some suggestions as to what to try to fix the "Power relay open" error? Thanks in advance.
