Need help with GX-640 calibration
jeff412
I just purchased a "new to me" GX-640 that I paired with my SP-540V to help free up some time for printing. The problem I have is that the cut lines are consistently off by 1/32" in the x direction and 1/16" in the y direction. I've tried:
1. calib function, but it doesn't make any difference.
2. offset under cropmark manual, but since I am using sensor, it doesn't make any difference.
3. cutting with and without laminate.
Is there an option to calibrate the cropmark sensor.
Jeff
jeff412
I finally got this fixed. There is a manual crop mark calibration in the service menu. I was able to correct the issue using it. Just thought I'd post in case someone else has the same problem.
Jeff
shuray
...GX-640 that I paired with my SP-540V to help free up some time for printing.
May i ask you how you paired this devices?
What software are you using?
How do you organize your workflow?
I have problem to pair GX-640 and SC-545EX
Alex.
jeff412
Sooo...how is accuracy on long cuts? 8' or more.
Not real good. We keep everything to 3' or less. So long jobs that we run through the SP-540V, we set them up to create a new page every 3' or so. That way we can run it through the 640 without problems.
Jeff Chambliss
stickertalk.com
jeff412
Alex.
I use Versaworks. I print, laminate then cut.
Jeff Chambliss
stickertalk.com
