Need help with network in the shop..
Discussion in 'Computer Hardware' started by Accelerated Graphics, Apr 5, 2010.
  1. Accelerated Graphics
    Accelerated Graphics Active Member
    889
    1
    18
    Jan 11, 2005
    Burleson
    I have 6 computers hooked up to my network at the shop. I have 2 computers when you go to "my network places" some of the shared drives are at the top of the page under" local network" and then the rest are below a line that says
    "unspecified"
    Can anyone give me some help so I can access all drive on these computers?
  2. briankb
    briankb Active Member
    746
    1
    18
    Jul 7, 2009
    Make sure your "workgroup" is the same on all PC's.
    what OS are you running?
  3. joeshaul
    joeshaul Member
    435
    Generally this involves getting them all on the same Workgroup. The procedure varies depending on the OS and "Views", but generally it can be found by Right clicking My Computer, going to Properties, then to "Computer Name", then click on "Network ID", set every computer up for the same, restart em all, and should be good to go.
    Some computers may not appear on the list if File and Print sharing is either not enabled or they are not sharing anything.
  4. Accelerated Graphics
    889
    1
    18
    Jan 11, 2005
    Burleson
    I'll try that in the morning..
  5. choucove
    choucove Active Member
    809
    You will also need to be sure that all computers are set to enable file sharing and discovery, which again varies depending upon which operating system(s) you are running. The easiest way to find out how to turn this on in your computer is just to google "How to enable file sharing in Windows"
  6. smdgrfx
    smdgrfx Member
    353
    Mar 9, 2006
    Houston, TX
    And also make sure the correct users have privileges set up. In other words make sure you can read/write and not just read. Also, you may want to just map a network drive for the folders you visit most.
  7. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    Yeah I even map some local folders so they are easier to find...
