Need Help Need help with Rolls Roller Flatbed application
Lindsey
Not A New Member
The bubbles appear immediately after applying clear laminate to decals.
Rolls Roller replied to my concerns and they said it was silvering which will go away in 24 hours. I would say this almost true but still have probably 10% of the bubbles are still there after 48 hours.
Of course they do not mention this anywhere on their website or YouTube videos.
Do you have any other types/brands of laminate that you can test with? The 1360z is very thin. It would be interesting to know if a thicker lam behaves the same way. You'd be able to rule out if the Rolls Roller is completely to blame.
If you have to use the 1360z for this job, I'd suggest increasing the pressure (if you can) & tension (if you can), and try laminating using a board (sled).
