Need Help!!!
Discussion in 'Miscellaneous Plotters' started by sean0115, Aug 8, 2010.
Thread Status:
Not open for further replies.
  1. sean0115
    sean0115 Guest
    I have looked all over the internet and cant find how to set my stuff up.
    I have a CR1200 http://www.cutterpros.com/proddetail.php?prod=cr1200 and Im trying to hook it up to Illustrator CS5 to print right from Illustrator. I am also using the latest version of snow leopard on my MAC.
    Sorry if this is answered somewhere else I couldn't find anything.
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,577
    432
    83
    Sep 11, 2003
    Olympia, WA
    According to the info at that site you need to have bridge software such as SignCut that will appear as a plugin for Illustrator. With that installed you will be able to get the vectors from Illustrator to the plotter to cut vinyl. The device is not capable of printing, however.
  3. sean0115
    sean0115 Guest
    Ya but signcut wont work with CS5? I guess Im asking how do I get this thing to print?
  4. Malkin
    Malkin Very Active Member
    2,194
    26
    48
    Feb 11, 2009
    Augusta, ME
    Try getting it to work with Inkscape instead (it's free, and listed as being compatible)
  5. Fred Weiss
    20,577
    432
    83
    Sep 11, 2003
    Olympia, WA
    It will never print. It is a vinyl cutting plotter.
    Do you have the SignCut software installed?
  6. sean0115
    sean0115 Guest
    Ya I know it wont print I ment to say cut and no I dont have the signcut software
  7. Fred Weiss
    20,577
    432
    83
    Sep 11, 2003
    Olympia, WA
    I do not think you will be able to cut directly from Illustrator. A bridge program such as SignCut is needed.
  8. sean0115
    sean0115 Guest
    will inkscape work?
  9. Malkin
    2,194
    26
    48
    Feb 11, 2009
    Augusta, ME
    I was just reading from the link you provided.
  10. sean0115
    sean0115 Guest
    So I can print right from inkscape and not have to download anymore software?
  11. Fred Weiss
    20,577
    432
    83
    Sep 11, 2003
    Olympia, WA
    Inkscape is an open source application that does many of the same things Adobe Illustrator does. All that the compatibility comment at your link means is that you can take the output from Inkscape and bring it into SignCut (and lots of other programs that are setup to bridge from a vector editing application to drive a plotter) to complete the path you need to cut vinyl with your plotter. Neither Illustrator nor Inkscape will drive your plotter.
    I mean no rudeness but again I will point out that your plotter has no capability of printing anything. When you use the word "print" instead of cut or plot, you are identifying yourself as someone out of his depth in what you are undertaking. What comes out of the vector editor, be it Illustrator or Inkscape, is mathematical instructions which must be translated into suitable code to drive your plotter. That is part of what the link you supplied is trying to tell you when they tell you that SignCut handles that part of your need.
    So yes, you need to pay someone for the plot program of your choice ... and their support in helping you get up and running.
Thread Status:
