Need Old Gerber Edge Info
Discussion in 'Gerber Omega, Graphix Advantage & MacImprint' started by Mark Fair, Jan 27, 2006.
  1. Mark Fair
    Mark Fair Member
    277
    1
    I am about to buy a used Gerber Edge 1. It includes Composer 6.2 software. My question is will windows XP support the older version of the Composer 6.2 software or will I have to run the Edge on Windows 98 or earlier versions of Windows?
    Any info would be much appreciated.
    Thanks,
    Mark Fair
    Mark Fair Signs
  2. Shovelhead
    Shovelhead Major Contributor
    10,882
    15
    I don't know about the XP issue but I would advise you...
    to do a CMYK test print with the seller to make sure that there are no blown pixels. It think it was around $3000 to replace the head.
  3. Fred Weiss
    Fred Weiss Merchant Member
    20,475
    369
    83
    Sep 11, 2003
    Olympia, WA
    Pretty sure GA will run on XP although I've never tried it. If not you can always upgrade to Omega.
    For a test print, I would recommend a 50% print of an 11.8" x 11.8" square using Spot Cobalt Blue.
    Most important: The printhead and cartridge cradle must be protected with the original shipping clamps or you will almost certainly break something when you move it or ship it. The original boxes are a big plus as well.
  4. Mark Fair
    Mark Fair Member
    277
    1
    Thanks Guys for the quick response.
    Also thanks Fred for the tips on boxes and transport clips.
    I will let you guys know how it turned out.
    mark
  5. GB2
    GB2 Very Active Member
    1,906
    80
    48
    Nov 15, 2005
    Connecticut, USA
    Graphics Advantage 6.2 will not run on Windows XP...it will only work on a Windows 98 system or lower
  6. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    Mark, you may want to loook into upgrading to Omega which will work on XP.
    The newest Omega just came out this month, & is not cheap, but if still available, an upgrade to either of the previous 2 versions should be somewhat less costly & still compatible with XP. Based on all the comments I've heard from GA users, it is a far better program.
  7. Mark Fair
    Mark Fair Member
    277
    1
    Just as I suspected, 6.2 will not work with XP.Fortunately I have 2 computers, one with Xp and one with Windows 98 (that drives my old 4B)
    Thanks Doug, I didn't think about an earlier version of Omega.
    Might be less costly than the latest release.
    Thanks for the help.
    I am excited!!!
  8. Arlo Kalon 2.0
    Arlo Kalon 2.0 Very Active Member
    2,466
    46
    48
    Oct 21, 2004
    Reno, TX
    Disagree... it's not SUPPOSED to work on XP, but I had GA6.2 on it about 10 months and it worked absolutely fine. YOUR mileage may vary. Oh yeah... and did lots EDGE printing w/ WinXP and GA6.2 - no problems.
    One thing to note is that I DID set the Composer program for WIN98 compatability in the XP Properties.
  9. Owen's Louvers
    Owen's Louvers New Member
    3
  10. Owen's Louvers
    3
    Microsoft Windows Millennium Edition
    winME is faster than win98se
    winME works just fine after you remove System Restore.
    Loads and runs GA 6.2 very fast and it is easy to handshake
    with EDGE and HS15.
    A free tool to uninstall System Restore from Windows ME,
    and it's easy to use! The filename to download is SRPsetup.exe.
    http://public.planetmirror.com/pub/majorgeeks/misc/?sort=date&order=asc
    srpsetup.exe 516.3 kb
  11. ndemond
    ndemond Active Member
    922
    I also agree, ran GA6.2 for about 2 years on XP. You can make it work.
    (Not sure how though, I didn't install)
  12. Edge Guru
    Edge Guru Member
    144
    Aug 1, 2007
    United States
    I to have also used 6.2 on XP, from 2002-2006. I upgraded to omega in 06. The only thing is that you need to remember is that you can not run the EDGE through the dongle, if you have an LPT dongle. So you need 2 LPT ports.
  13. vw4fun
    vw4fun New Member
    9
    Don't let that Isla Mujeres, Mexico cat fool you. He knows what he talking about. He still paying for being a draft dodger.
  14. Owen's Louvers
    3
    Captain,
    Is that you? It is good to hear from you.
    It’s been a long, long time. Life is beautiful
    here on the island. Most days I visit the ghost
    of my cousin Jean Laffitte. He was the real
    Pirate of the Caribbean.
    Sail down and visit if you get a chance mate.
    My address is:
    16…..16…..16 Paradise
  15. a+signgal
    a+signgal Member
    27
    1
    I am running my Edge with Sign Lab software. It works great. If you use GA there is a patch to download so you can run it on xp. If you want to sell the GA I am looking to buy that software. My dongle went out on mine and the files aren't importing correctly into sign lab. I have 10 years of files with graphics advantage.
    A+ Sign Gal
  16. OldPaint
    OldPaint Major Contributor
    i would check the VERSION OF XP 1st.
    if its XP without SP2, i would say it will run GA.
    if SP2 is in the XP, it will cause problems.
    iam running this machine with XP PRO SP1, and works fine.
    my laptop has SP2 and will run plotter just like the SP1.
    but a lot W98SE programs dont work in XP SP2!!!!
