Need some help in FlexiSign (scale)
Discussion in 'Flexi' started by MTechGraphics, Mar 31, 2007.
  1. MTechGraphics
    MTechGraphics Member
    98
    I have flexiSign 7.6 and I purchased Mr. Clipart vehicle templates. The templates are made in 1:20 scale. I use AI and flexi to design, but how am I supposed to get the real size of the design in AI so it can be imported into Felxi or Cut Studio (Roland Software)? I know I need to zoom in I think about 2000% ? maybe I'm not sure if you guys can give me a small list of steps I can follow it would be great.
    It's my first time using the templates and I need some help from someone who has done this before.
    Thank you in advance to everyone who will be willing to help me on this one.
    :signs101: ​
  2. anothersign
    anothersign Member
    307
    1
    18
    May 28, 2006
    Illinois
    you are correct
    go to resize and make it 2000% and it will be to scale.
  3. signage
    signage Major Contributor
    9,314
    41
    48
    Oct 5, 2005
    Penn
    Rather than make the file bigger just design at the reduced size then scale up at the print/cut export or scale it in your rip!
  4. MTechGraphics
    98
    I understand that about designing in the scaled file. Anothersign resize? where in AI or flexi? Also if you can tell me where to find resize that would be great because I'm new to all of this. I'm trying to learn as much as possible and this board is the best out there.
  5. gvgraphics
    gvgraphics Very Active Member
    2,182
    2
    Click arange, then resize. In the design box you will see 100%, change that to 2000% and you are all set. Or on the left hand side of your cut manager you will see where it says size. It will say 100%, change that to 2000%.
    Sean
  6. Drip Dry
    Drip Dry Very Active Member
    1,122
    1
    38
    Aug 11, 2004
    Long island NY
    If you have Flexi, then why are you using AI just to resize ?
    You can import the file directly into flexi and make your changes there.
    Watch this video demo http://www.givemehelp.com/fullflexi8demo.html
    (thanks to Bradster)
    and pay particular attention to design central. It shows how to do what your looking for.
    Jim
  7. MTechGraphics
    98
    Thank you guys so much for all your help and support all the tips worked great I finally got it. This board is the best!!
    everyone that helped me rocks!!
  8. mark in tx
    mark in tx Very Active Member
    2,081
    Oct 25, 2005
    Harker Heights, Texas
    Select the object, then hit ctrl-K
