Need some help with vinyl express Qe60+
Discussion in 'Miscellaneous Plotters' started by ba1980, Apr 15, 2008.
  1. ba1980
    ba1980 Member
    33
    I got a new Vinyl Express 24" cutter/plotter (Qe60+), but I'm having some trouble cutting with it. I have a roll of 15" Oracal 641 vinyl in it with the text going the width of the vinyl. It won't cut all the way through the vinyl on the left side, but will on the right side. Is there some settings I need to change? If so, what do I need to do?
    Bill
  2. Sparky
    Sparky Active Member
    586
    Make sure that the software you are using is not sending along pressure and speed settings to the cutter. Adjust the pressure/speed on the cutter, not in the program.
  3. ba1980
    ba1980 Member
    33
    I'm trying to useFlexi 8.5, still don't know much about it. I couldn't find anywhere in there that would let me adjust pressure/speed. Would it be sending different settings to the new cutter as it is the same program I was using with the old cutter (Lynx s-30)?
    I had it somewhat working last night, but not ideally working as it was cutting deep in to the backing.
  4. Redline Signs
    Redline Signs Member
    111
    One time my vinyl express panther did simular stuff you are experiencing. i called their tech line and the dude had me lower my downforce to it default and pull the blade out a bit. Has worked great ever since.
  5. MrKoob
    MrKoob Member
    270
    It could be a software override issue, then again maybe not. I don't have a software screen in front of me so bear with me, but when you click the "Cut/Plot" Button, Select the "Advanced Tab", then "Driver Options". Select "None" on the drop down box. This should disable the Software from controlling the cutter. I don't know if this will fix your problem.
  6. ba1980
    ba1980 Member
    33
    Do I really have to tell you all what was wrong?
    I didn't have the blade holder all the way in. I really hate to admit that though.
