artbot
i am in a pickle. no time. huge project. don't trust my current materials and techniques for the miracle that has to happen in the next five days.
i have a 211 x 38 diptych to do. two layers. metal on the back, acrylic floated slightly larger about 1.5" over it with a second image mounted on the front of the acrylic. the wall is slightly concave.
usually i would print the top layer on a .040 PETG and mount that to the acrylic using a special clear epoxy. keep in mind this is a textural print that looks like melted glass. the image can not go on the back of the acrylic.
the epoxy will not cure fast enough, also i don't trust it for the next fifty years being concave. it's a tricky material that i do not like using.
________________
what type of film might i use? ...needs to be optically clear, never have any yellowing or peeling or delamination issues that could be wet applied? this material would be exposed to solvents during fabrication during the process so it can't fog up if i were to spray it with lacquer thinner.
possibly it might be better to use a pressure sensitive polyester? but i'd need to allow for time to run it to someone that could mount it and we have NO time for any hiccups in the fabrication.
thanks in advance.
________________
thanks in advance.
